8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible), 57 guests, and 4 robots.
Topics128,075
Posts1,055,919
Members48,429
#52093 11/08/2005 4:39 PM
Junior Member
Junior Member
I've settled on a 261 for my '46 1/2 ton. Is there any sure way to tell a 261, from a 235, visually, or will I have to do the numbers thing???
Thanks, jj
overthehillracer
#52094 11/08/2005 6:10 PM
http://www.stovebolt.com/techtips/engine_identification.htm
The captains bars are not always reliable, best to run the casting number.
Fred
52 3600
69 C-10
#52095 11/10/2005 6:52 PM
What exactly is meant by raised captain's bars?
A block I had in question has the following raised lettering by the starter, CON 4 L66. Since these are raised I questioned if it was a 261.
The serial number on the pad by the distributor is a real funky one in my opinion, FI2I7H. I wonder if this isn't a rebuilder number?
Finally the block casting number on the left side of the engine shows 3837004 which Inliners web site does indeed show it to be a 55-57 235 cu. in. engine. Since this is in a 1960 Apache 30 it shows the engine has been replaced with an earlier one.
Word hard, play harder, enjoy life!
#52096 11/11/2005 4:57 AM
V
V Offline
Windy: Try this link to understand the captain's bars.
http://www.oldchevytrucks.com/cgi/htmlos.exe/002719.5.2761373638100007788
#52097 11/11/2005 8:04 AM
X
X Offline
Windy: That serial number is the standard form used from '57-up. This one tells that the engine was built at the Flint plant (F) on December 17 (1217), and the H suffix is for the regular production Thriftmaster 235 used in the '57 31-32-36-3800 series trucks. The block casting date code (L66) decodes to December 6, '56 in this case.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#52098 11/11/2005 5:08 PM
Thank you so much for the serial number information. I am glad to know exactly when the engine was produced.
VFT, the Old Chevy Trucks sites links you give always give me a listing denied window rather than the thread. Thanks for posting it anyways for the others that might be able to access it.
#52099 11/12/2005 2:32 AM
V
V Offline
Thanks. I'll check it out and figure out why.
#52100 11/12/2005 2:49 AM
Hey VFT Gimme a call or an e mail
Regards Steve sr. wink wink
#52101 11/12/2005 2:57 AM
V
V Offline
Email has been sent.
