7 members (GMCJammer51, TexasA&M48Truck, 55shaker, Gdads51, Pre '68 Dave, moparguy, 3B),
106
Mod | | | Forums66 Topics128,091 Posts1,056,390 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 6 New Guy | | New Guy Joined: Dec 2008 Posts: 6 | Hey fellas/gals, I am putting a 350 in my 62 restoration project. I am keeping the hydraulic clutch (I hope).
I have the 350 engine and a bell housing for the V8 with the fork arm on the passenger side (needed for the hydraulic set up). I am planning on using the world class t5 from a camaro with the 26 spline input shaft.
I have a couple of questions:
I have a camaro flywheel which slightly touches the bell housing on the passenger side when installed. I could probably use a grinder and take off the sixteenth or so to give it enough clearance, Is this a problem or or is there another flywheel I should consider. I checked a 4.3 astrovan 1987 and it is the exact same diameter as the one I got from the camaro. The od is 14.12 inches and has 168 teeth.
What clutch disc and pressure plate are folks using?
What Pilot bearing and starter as well?
I know I may have bench seat issues and once I get it all fit up if the bench wont work I will go with bucket seats or try to modify the shifter slightly.
Thanks for any help or suggestions. David | | |
