10 members (JW51, 68ironhead, baldeagle, Guitplayer, 2-Ton, walter74, Eisenholtz, Peggy M, joe apple, WICruiser),
82
Mod | | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 130 | The angle of my steering column on this '34 pickup is not such that it will meet up with the bracket on the dash, infact it's out about two inches from that point. Is there an adjustment for this?? I tried a bit of torque on it but it is locked to that position. I suppose I could live with it but it really pushes the room between the seat and wheel to a minimum. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | You might try loosening all the mounting bolts, then see if it'll move where you want it to go. Don't forget to retighten them!! A small change where the box is bolted can make a big difference at the end of the column. You might also be able to oblong the holes a little and make it work. | | | | | Joined: Feb 2008 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 130 | Thanks for that idea! I am sure one of those will work--like you say--just a bit of change at the mount will make ahuge change above. By the way yout green truck is really outstanding. Good work! | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Thanks. Wow, ya don't see many '34's around anymore. That's going to be one cool ride. Keep us posted with pics. | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I'm not familar with the '34, but the earlier steering gears are clamped to the frame. You can loosen the bolts and it will rotate up. | | | | | Joined: Feb 2008 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 130 | Good thanks for that too --sounds like I will have some added room there in short order. It was looking kinda meager for a while | | | | | Joined: Feb 2008 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 130 | Yes all I had to do was loosen and reposition--thanks alot! | | |
