4 members (dunfire, John Dlugos, Gdads51, Greg_H), 69 guests, and 8 robots.
Topics128,187
Posts1,057,211
Members48,465
I put on 1946 led taillights and everything was working fine. I think the front turn signals were a little faster and brighter but the change was minute that's why a can't tell. Everything was working fine for about 200 miles now I noticed the front left turn bulb isn't working. I replaced the bulb and the front running light works but not the turn signal. Could the led draw too small a current and fry the turn signals?
Rick
No, too small a current won't fry a circuit. Not enough resistance will cause a flasher to flash faster. This will happen when one bulb burns out on an incandescent system. That's why your front flashed faster when it worked. They make special flashers for LED systems but I don't know how they work on a split system.
But that's not your problem. It appears you have an open circuit. Use your multimeter to find it.
The led systems require a flasher that is diffrent in design. They are a quicker resistance in the points cut off.
Just replace it with a led flasher like cletis stated.
This will fix all your problems. Infact you could replace your front marker lights to with the Led replacements and be just fine.
Leds do require more resistance in the voltage and the Flasher will fix that
Poets Seat Auto
Appraisals, Parts, Service
Past: General Motor's Master Technician
Member: Northeast Chevy/GMC Truck Club
Phone Number: 413.774.5856
Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
I've installed led signals on motorcycles and not changed the flasher all it requires is a resistor in line to add the difference to make the flasher operate correctly.
I'm running LED rear turn signals and conventional bulbs in the front parking/turn sockets. The standard flasher works fine as long as there is resistance from the front bulbs and the electronic flasher I tried didn't function.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
thanks for the info. i'm not the best at electrical but i'm learning. like dont grab the spark plug wire. not a good idea.
Rick.........
I worked at Rogers Stereo and have done a lot of custom wiring. Had a lot of experience with wiring, so if I can be of any help let me know.
I knew there was somthing about LED lighting that was a worry for people that change thier systems over. I forgot what it was. And now that it has been posted I remember. The turn signal flasher was the item of fault. Geeze I love this forum.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
