I suppose it would depend on what parts you need. I know that stuf like the pinion seals and 3rd member parts are the same as the rear axle, and I have read that the knuckle seals are the same as Dodge Power wagons of the same era. You might also ask on
Napco4x4. I also seem to recal that Jim Carter did Napco stuff, but I'm not sure if they still do or not.
