3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#51986 11/05/2005 10:58 PM
Apprentice
Apprentice
Has anyone swapped a later model chevy truck front suspension onto a 62 with torsion bar front. OR..... Is there a junkyard find set of spindles out there to convert my drum brakes to disc and five lug on a low buc build.
#51987 11/06/2005 6:33 AM
i seem to remember hearing that the 67-72 frontends can be used for this purpose. and there are a lot of those out there to choose from.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#51988 11/06/2005 10:11 PM
V
Junior Member
Junior Member
V Offline
I just finnished putting a 75 camero under my 51 AD. not too difficult, lots of measureing and head scratching, chassis must be on jacks and perfectly level, front to back and side to side find center line of front axle, measure back 20 inches or so, on my truck it was just ahead of the foreward cab mount, do the same with the sub frame,leave 4'' for overlap than cut both . pick up sub frame with a cherry picker and move it into place, lots of trying and fitting to do. place a place a degree level on one of the top A arms 6deg. is a good place to start, tack weld and check for looks check your scrub line from bottom of front wheel to bottom of back wheel ( wheel not tire)
amount of rake is determined by degree of caster on a frame i try to stay high, you can always torch a spring coil. good luck
