| | | Forums66 Topics128,091 Posts1,056,393 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | My dome lamp quit working and finally diagnosed the problem. Before you go through all the steps first check for power at the lamp assembly and then check the springs that press the connections together in the lamp assembly. You might find out after 50+ years the springs may be collapsed and wire tip may not be reaching the bulb contact(s).
Steve in Idaho | | |
