5 members (treegrower, Bill Hanlon, Hotrod Lincoln, HandyAndy, FAST55), 186 guests, and 7 robots.
Topics128,077
Posts1,056,015
Members48,433
#519383 03/21/2009 10:15 AM
TPB
Offline
my truck is leaking anti freeze`from back where the transmissio and engine meet. my mechanic recomends use a stop leak product he says he would need to pull the motor to fix it. what do think the problem is and should I try the stop leak stuff?
TPB #519387 03/21/2009 10:48 AM
If you're going to keep the truck have it repaired properly with new freeze plugs. The "stop leak stuff" is not a reliable repair.
ttodd #519393 03/21/2009 12:02 PM
To fix it you definitely would need to pull the motor. Here is a photo of when I replaced mine. I did it when I was replacing the toe board in the cab.
http://rides.webshots.com/photo/1316417356041873203xTDshC
As you can see, there is normally no access to the area.
1951 1 Ton Completed
What the heck kind of place is that for a frost plug??
1951 3800
-hotshoe
Riding in the Passing Lane
These plugs were not put there for "freeze or frost" protection. They are called core plugs & are used to seal the openings used to remove the casting sand after the block is cast. If cooling systems are maintained & they are replaced at rebuild they will last the life of the engine.
1972 Chevy c10 Cheyenne Super
H Online: Content
Another sneaky trick is to use brass plugs, not steel. They last a lot longer without rusting out!
Don't ya wish we all could have a Wrenchbender or Hotrod Lincoln as our neighbor? I'd be knockin on there door all the time.
