1 members (5 Window 9434), 68 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#519213 03/20/2009 7:08 PM
Both for a 53 3100.
Rear bumper.
1. - does the bumper brackets go on the outside or inside of the frame? They have two holes which do not line up with holes in the frame. What is up with that?
2. - has anyone used a front bumper on the back of their truck? I have two front painter bumpers and would like to use them.
TIA
Dennis
Y
Y Offline
What I found out, my 53 is mounted on the outside. I tried to mount it inside and it was to close to the license plate, and you won't have any adjustment, what little there is. Front bumper/frame is "narrower" and brackets are different.
There is a much greater curve to the front bumper than the rear. I don't know, but I guess a front on the rear would not work due to the curve even if you could get the brackets to work.
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
Nifty 50 #519234 03/20/2009 8:36 PM
Use the brackets from the rear of a Suburban or panel to put a front bumper on the rear of your truck.
