1 members (GMCJammer51),
122
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Both for a 53 3100.
Rear bumper.
1. - does the bumper brackets go on the outside or inside of the frame? They have two holes which do not line up with holes in the frame. What is up with that?
2. - has anyone used a front bumper on the back of their truck? I have two front painter bumpers and would like to use them.
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | What I found out, my 53 is mounted on the outside. I tried to mount it inside and it was to close to the license plate, and you won't have any adjustment, what little there is. Front bumper/frame is "narrower" and brackets are different.
| | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | There is a much greater curve to the front bumper than the rear. I don't know, but I guess a front on the rear would not work due to the curve even if you could get the brackets to work.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Use the brackets from the rear of a Suburban or panel to put a front bumper on the rear of your truck.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
