7 members (Gdads51, Phak1, Joe H, Youngin' Tut 59, Greg_H, carbking, Wayne67vert),
99
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,137 Posts1,056,430 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i bought this used hoist a couple of weeks ago. it worked at the time. turned it on it's end loading it on a trailer and some of the fluid ran out. then today pulled engine around with the wrecker and the hoist/ cherry picker won't lift it to get of the wrecker. :mad: added fluid thought maybe some air in there. it will lift but not enought to raise arm. any suggerstions? i would like to start using this thing. rassled with the engine all day. had to change out oil pan and gasket, but i want to get started on fab'n the motor perches. thanks, hr | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | usually helps to have it fully extended when you add oil - remember to cap the hole b4 you let it down  Bill | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | If the fill hole is on the outer part of the cly. like the one I have set it on the bench and fill it up with out extending it that is the holding tank when its retracted , I use a hipo with no needle , than when You use it for the frist time it will bleed the air out into the outer section .Pete | | |
