| | | Forums66 Topics128,261 Posts1,058,345 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 13 New Guy | | New Guy Joined: Mar 2009 Posts: 13 | hello . in england we call them windscreens im sure you call them windshields ,the front glass of a car ..anyway , im fitting a new one on my 54 chevy pickup , i have had a go and failed ,,,got any tips on fitting one please ?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the garage gish, there's enough Brits here we understand your mangling of the language  call'em what you will, they're never easy to install! see if this tip is helpful - if you elaborate on the particular problems you're having someone might be able to advise more Bill | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Hi gish, firstly welcome to the 'bolt from a fellow Brit! It's O.K I speak your language! (Well...almost!)If ye ken whit ah mean! What was the problem you encountered? As Bill said they can be tricky. The one piece glass is generally easier than the 2 piece(pre '54) More info,or even better... pictures will help in the diagnosis. Jock
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Do you have the stainless steel trim that surrounds the 1954 windscreen glass and is inserted into the seal? I have found that installation to be tricky.
Nonetheless, the standard seal with no ss trim should not be too difficult.
From whom did you buy the seal? From whom did you buy the glass? What are the problems you are having?
| | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Be sure the opening is free of any rust or old glue. | | | | | Joined: Mar 2009 Posts: 13 New Guy | | New Guy Joined: Mar 2009 Posts: 13 | the tech help ,helped , it was a real simple job in the end ,with 2 people ...i followed all the advise the window went in but i used a window rubber that has the chrome strip to go with it ,,,but i dont have the trim so i pulled it out again and used a normal rubber ,,and BINGO ,,,i look out and see stuff ...project 1 of 10 completed thanks
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Good to hear you got it sorted Gish... Now get on with the other 9 projects!  Keep us posted of your progress. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2009 Posts: 13 New Guy | | New Guy Joined: Mar 2009 Posts: 13 | | | |
