| | | Forums66 Topics128,141 Posts1,056,779 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | Can I adjust valves with HYD lifters? I have a 55 235 from a car in my 58 and I have a little miss when idling that you can see on a vacuum gauge. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Do you have a Shop Manual for the year of your car's engine? Have you tried the procedure for adjusting hydraulic lifters that is in there? There is a Tech Tip with information on adjusting hydraulic lifters but the technique/setting is questionable. Here is a better article on adjusting valves. It has advice on adjusting hydraulic lifters at the bottom, as follows: If your 235/261 is equipped with hydraulic lifters, the adjustment procedure is the same, except you carefully adjust each valve to zero lash when it is in position, then give the adjusting screw 1/4 turn more and lock the nut. After all are done you must run the engine and whilst it is idling, adjust any valve that clatters only just enough to make it stop clattering.
Some folks will tell you to set zero lash then 1-1/2 turns more on the adjusting screw; this is wrong, and will result in misfiring and burned valves.
Be aware that the 235/261 engine design isn't good for installation of hydraulic lifters, and once the engine is fully broken in, the oil pressure at idle will not be sufficient to keep the lifters pumped up at idle, leading to clattering valves again. Later blocks have larger oil galleries in the lifter areas to provide the increased oil flow required by hydraulic lifters but normal hot idle oil pressure in these engines is under 20#; this isn't sufficient to keep the lifters pumped up.
So don't be in a hurry to add hydraulic lifters when you're building your engine; they rob power and are usually unsatisfactory in service. | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | Had one that had a miss just like you described.After adjusting them twice,It was still missing,So I'm standing there scratching my head and decide to do the redneck thing,I started er up and pushed and wiggled the valves with my fingers,I think it was on number 5 the miss went away when I was applying pressure.Turnes out the valveguide was bad on the one cylinder.An easy fix and the motor was as good as new!!Tom | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Tom,
You must have some secret method as I consider a valve guide replacement major surgery. Did you mean a sticking valve in a guide or more likely a valve lifter.
Stuart | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | Nope,I mean pulling the head and having the valves done up at a shop.I dunno,seems like a simple fix to me,it's just a 6 banger.Easy to pull apart and put together!Tom | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Tom,
Yes, a simple fix. I did the same thing a few years back when I had a stuck valve (from sitting too long). Not too expensive, and it was quick and easy. However, the lower end of that engine gave out, about 4 years later.
Tim
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Just a basic question here - are you sure you have hydraulic lifters? Here's an easy check, if your engine ID number, the one stamped just behind the distributor, ends with "Y", then yes, it has hydraulics. Anything else in '55 had solid lifters whether it was in a car or not. | | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | It is nice and quite compared to other trucks that I have heard running and originally had a PG. I bought the engine and installed it myself.
