1 members (Danielbolt),
164
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Got new rubber hoses that will be changed when I install my already purchased dropped axle(55 chevy truck). How do you install them so they don't twist all up when tightening Does loosening the nut on the other side of the frame prevent that?
Keith | | | | | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | Tighten it onto the wheel cyl.first and then from the metal brake line,twist the nut into your new rubber line. Thats how it is on my 54. I just bought a 3" drop axle from Sid Drapal. What did you get? | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | 3" from SID here also..I've had it for about 6 months but haven't installed it yet..Possible next month | | |
