2 members (artinva, Chip O), 112 guests, and 2 robots.
Topics128,072
Posts1,055,904
Members48,429
#517473 03/15/2009 8:46 PM
So I have a vacuum leak and found it to be the advance on the distributor. So now in my searches I have found some who say the car and truck units are different. I believe that my motor was originally from an early 60's car but don't know how to tell for sure. I really don't care if it is the correct looking unit I just want it to work properly. I'm just hoping you guys can educate me on stovebolt vac advances before I go out and order something tomorrow and have it be wrong.
Thanks, Chuck
their should be at part number on the advance see if it can be crossed or identified from it !
old dog #517540 03/16/2009 12:12 AM
The car and the truck vacuum advance units have different angles
car unit - photo 1 (oddy - this photo of the incorrect unit is shown in truck Shop Manuals & Owner's Manuals)
car unit - photo 2
car and truck units next to each other
common replacement unit - the pivot post on the moving arm must be drilled out and your original crew should be used
So either car or truck will work, just the angle of the vacuum canister is different. Thanks for the education guys.
