1 members (Phak1), 48 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#517107 03/14/2009 8:13 PM
One side of the head gasket I bought for my '58 235 is all metallic, and the other side is standard composite gasket material. Does it matter which side goes up toward the head?? I'm afraid of putting it in backward! My second question is, should I use gasket sealer material on the head gasket? The head and block were resurfaced and the gasket is new. I've read other posts on this topic, but there seem to be as many answers as there are questions. Much thanks!
Norcal49er,
I'm going to be dumb and say that your head gasket will only fit properly one way. I don't believe in sticking anything on a nice new head gasket as it's pretty much a mechanical seal especially after decking the block and surfacing the head.
Stuart
atomarc #517114 03/14/2009 8:41 PM
Apprentice
Apprentice
Back years ago I was taught to put them on dry, no gasket sealer. I have done that for years and never had a failure. Which side goes up I ussually deternimed by the way the holes lined up on the head and block. The water chambers and oil ports have to line up and not be blocked.
My 2 cents if it helps.
All of the holes line up regardless of which side is up. Nothing is stamped on the gasket, and there were no instructions in the box.
I was under the impression that it only fits one way. I am used to seeing some lettering on it somewhere to identify which side is up.
1951 1 Ton Completed
truckernix #517147 03/14/2009 10:15 PM
norcal49er,
As Fred states, some gaskets indicate 'engine side' or 'this side up'. I looked in an old book I have and it clearly states the head gasket will only fit one way to allow all the coolant holes a clear path. Maybe the '58 has done away with this requirement. Check real close and look at all the holes, I'll bet some are covered when they shouldn't be with it flipped the wrong way.
Stuart
norcal49er #517158 03/14/2009 10:48 PM
Thanks, guys. The 3rd time I checked it, I noticed there is ONE hole that is not symmetrical. The metal side of the gasket goes down!
NorCal,
I had the same problem. I called the gasket co. that made the gasket i was using, they told me to spray the metal side with Copper Gasket adhesive you can get from Napa and the metal side goes against the block. Hope this helps.
Patrick
