4 members (Jon G, Joe H, J Lucas, Phak1), 74 guests, and 3 robots.
Topics128,050
Posts1,055,646
I stripped down the engine to do some detailing and now that I'm putting some of the stuff back on I have a concern about the distributor. I thought I remembered the metal tab that has the degree marks sitting flush on the block but when I put the distributor back in it sits about 3/16" above the block. I took pics of the engine before stripping but of course this particular location doesn't have a clear straight on view to confirm my memory. I didn't rotate the crank while apart and it looks like the flat end of the distributor shaft is lining up with the slot at the bottom of the hole and the gears do mesh. So am I losing my memory or is something not right here?
"If you're not first, you're last". Ricky Bobby
1944 Chevy Firetruck
Halloween Decorations
1966 F**d Firetruck
Is there a chance that the vacuum advance unit is now further up on the distributor post? Did you loosen or remove the vacuum advance unit?
ddalesr3,
Keep in mind that when inserting the distributor, because of the helix of the gears you must 'lead' the final position of that slot you see down in the hole.
As you slip the distributor in, the shaft turns and has to be timed to fit the oil pump slot. If you do this with the cap off you will see the rotor turn as you slide the unit down. Make sense!
Stuart
Or, are you sure that the tang on the end of the distributor shaft has slipped into the slot in the oil pump drive shaft? If you hold the distributor housing and slowly rotate the crankshaft the distributor should fall into place when the tang aligns with the slot. Even if the engine was not disturbed, I have found that the tang does does not always slip into the slot. I have inadvertently installed the distributor one tooth off (1/13th of a turn), and the "Engine Disturbed" Distributor Installation instructions from the Shop Manual must be followed.
Hoyt
Try turning the oil pump drive with a long screwdriver (just a little) so the drive tang on the distributor drops into the slot as you insert the dizzy. The shaft is sitting on top of the drive instead of meshing with it.
