2 members (Wheelie, Jimmie D),
125
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 43 | | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | That looks very close to the washer bottle mounted on my 1964 Impala. The one I have has a paper label on it. They also made plastic bottles in later years that fit into the same bracket. Good luck. Jim | | | | | Joined: Dec 2008 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 43 | Thanx Jim, close to your 64 so for our 65 it's era correct enouph for me, I'll buy it today  | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | Some did use the OptiKleen bottles but some, like my '63 C20, used the plastic reservoirs like this.
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Where does that thing mount? Anyone have a picture? What did you use for a pump? I have a 55.2 and the washer system was missing. I believe that is the same bottle I need. Thanks Michael | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Michael - not the one for TF trucks [which was an option, so is usually "missing"] - see here for foot operated, and here, push button operatedBill | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Then that would explain why its missing, it was never there! Those diagrams look like the bottle is mounted where the voltage regulator is? If anyone has installed a washer system on a 55.2 I'd love to see pictures. Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | more to the center than the regulator - inboard of the wire harness grommet, just above where the e-brake rod is
Bill | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | Bears63 The OptiKleen bottle was just used to refill the plastic jug when it was empty. My 64 Impala also has a plastic jug like what you showed. Jim | | |
