4 members (1955 1 Series, Otto Skorzeny, DaveV, Southerntruck), 78 guests, and 0 robots.
Topics128,115
Posts1,056,294
Members48,439
#51605 10/28/2005 5:45 AM
Apprentice
Apprentice
i have a 2 barrel carb on a 307 gmc engine it needs to be replaced popular opinion says to replace with a 4 barrel which would take me off the road for awhile without a garage to do this right for example new manifold etc..... so i want to replace this for the moment with a new 2 barrel where do i find a decent new 2 barrel carb or what kind of throttle base plate do i need to get to have a 4 barrel mount on the existing system i am using now has this ever been attempted with a 4 barrel on a 2 barrel mount
#51606 10/28/2005 11:11 AM
You might try www.cliffordperformance.net
or Tom Langdon, www.stoveboltengineco.com
Jegs and Summit both sell Holley 2 and 4 Bbl carbs and Edelbrock 4 Bbl. Two barrel Holleys come in 350 and 500 CFM. Edelbrocks start at 500 CFM (but no 2 Bbls).
www.jegs.com
or www.summitracing.com
I don't think you can squeeze a 4 Bbl onto a stock manifold. You may even have trouble with the aftermarket 2 Bbl types. However, I am completely unfamilar with the early L6 engines. When I converted my stock '68 292 from a Rochester Monojet to a Holley 390 4 Bbl, I had to replace the stock manifolds with an Offy 4 Bbl intake and Clifford headers. I was pleased with the results, but it was not as expensive in '78 as it is now to get the same parts.
Every 25 years I like to rebuild that 292 just for GP
#51607 10/28/2005 2:50 PM
ebay motors
they are usually pretty cheap, but it may take you awhile
Jim & Caroline
#51608 10/29/2005 11:40 PM
Carburetion specialist
What kind of a G.M.C. 307??? My listings show a V-6 305 with Stromberg 2-barrel carbs, and an L-6 308 that used a variety of Zenith and Stromberg 1-barrel carbs. I have no record of a G.M.C. 307 (listings 1913 - 1974).
Using a 4 barrel through a 4 barrel to 2 barrel adapter is a total waste of time and money. If you want more carburetion, best to buy a larger 2 barrel or change the intake manifold.
Jon.
The Carburetor Shop
