2 members (Rusty Heaps, PAUL Berardi), 141 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
What is a good product to use for cleaning and polishing chrome and stainless steel? I read on this site that #00 steel wool or emery cloth work well, but what about the polishing compound itself? Any recommendations?
This set from Eastwood Company works quite well for me.
My stainless was in pretty good shape, so it only had very mild scratches. The compounds were sufficient to remove the minor scratches.
Y
Y Offline
Steelwool is not recommended for polishing chrome, do a search and you will find lots of info, on the topic.
The best product that I have found is a metal polish/cleaner called Autosol.
1951 1 Ton Completed
My favorite is a product called Wenol. Our local car paint store carries it. Work wonders for just polishing by hand.
http://community.webshots.com/user/49chevyman?vhost=community
"The only people who do not make mistakes, are people who do not do anything."
I
I Offline
You dont need to polish chrome...it will need cleaned but it will not polish The finish is the best it gets some is beetr then others. But polishing on it does not make it brighter just cleaner.
SS you can polish but it is very tough.
Our company makes a good all metal polish.
Go to Meguiars.com and you will find it there
I use the same stuff as Truckernix, Autosol. Then I generally use Neverdull, afterwards, and to generally keep it up. My headlamp rings are starting to show brass, so I end up using the Neverdull about once a month. If there is lots of detail, I have used bronze wool, and then Neverdull.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
