| | | Forums66 Topics128,087 Posts1,055,999 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 3 New Guy | | New Guy Joined: Apr 2006 Posts: 3 | I am in the process of restoring a 52 Chevy pickup.I believe the original was a shade of green,pretty dark green.Can anyone tell me the correct color of the body and interior as well as frame,engine compartment and engine also ?What type of paint,single stage I would assume.Wheres the best place to purchase and what type of primer,reducers and hardeners etc. to do the truck.One last question ,how much of each? Thank you | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Probably Forrester green, but see the sticky post labeled "Paint Factory Colors" at the beginning of this section. It also details what parts were painted what color. As for how much, I would budget 1.5 gallons of paint with an HVLP and 2 gallons with conventional sprayer. The primer and reducers you use need to be compatible with whatever top coat you chose for the truck. Your paint supplier will be your best resource for this.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | Woodchuck08....The best advice I can give You, whatever brand of paint refinish system You choose stay with manfacturers full refinish system. If You use Dupont paint then use their full system, primers, hardners, sealers ect. If You choose Ditsler stay within their system...If go out of the system You'll be sure to get into trouble, plus You have to start over again...More $$$$$ My truck is Forrester green, which is a low hiding color, My advice to You is, I took Dupont's clear tintable sealer and using 99L Black, sprayed one wet coat, allowed it to flash, then came back with a 2 qt. pressure pot and got complete coverage in one coat, I gave it 4 coats...4 coats of clear with color mixed in clear Bill B | | |
