1 members (baldeagle),
73
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 30 Apprentice | | Apprentice Joined: Apr 2007 Posts: 30 | I've searched here a little bit but didn't find what I was looking for, so here goes. I'm not getting a good ground on some of my tail lights, turn signals, etc. so some of them did work but now they don't. It made me wonder about using ground wires instead of using the body or chassis. Has anyone done that? How did it work? How did you figure the wire size needed? Thanks! Dale | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Dale,
Modern rigs usually have a wired ground system but I thinks it's because most everything is plastic. If you were a glutton for punishment I can't see any reason not to run separate wires for all the grounds. If all the light assembles and what-not are mounted on clean shiny metal, a separate ground system would be redundant...and sort of silly in my mind.
As far as wire size, because the device eats up some power to perform its function, I would thing a separate ground wire could substantially smaller than the supply side wire.
The mating contact between things like a taillight housing or a horn would have to be real cruddy for it not find ground.
I have not seen any threads in this forum that discussed this idea, but again, I haven't searched. Good for you for digging around first.
Stuart | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It takes a supply path and a return path to supply any load. Therefore the size needs to be at least the minimum to supply that load. If you have a ground wire servicing two loads, it needs to be heavier then the two supply wires to do the job.
You should be able to use the frame of your truck as the "big ground bus". However, relying on a ground path from a light through sheet metal is folly. The easiest solution is to run a short ground wire from each light fixture to the frame. | | | | | Joined: Apr 2007 Posts: 30 Apprentice | | Apprentice Joined: Apr 2007 Posts: 30 | Thanks for all of the responses! Looks like I need to add some ground straps between all of the major components and some short ground wires from the lights. Thanks again! Dale | | |
