1 members (Hotrod Lincoln),
125
Mod | | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 91 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 91 | Are any of the internal parts interchangeable, rods,pistons,crank.? Thanks | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Is that a 216 in your 36? I am not real familiar with the early Stovebolts, but I have been told that 1937 was the first year for the 216. Link to some information on the early Stovebolts. There is probably not much interchangeable between the 1936 207 (if it still has the original engine) and a 216, as the 207 had a three-main bearing crankshaft. At least they did in 1934 . Hoyt | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | The 36 - 206.5 engine is different from the 216 engine. It is slightly longer, the side covers do not match, the timing cover has one less bolt than the 216 and the rear motor mounts are set up differently, among other things. The 216 from 37 to 40 is a version unto itself. In 41, Chevrolet redesigned the 216 and the configuration of the block is different from 37-40 along with some other redesigned items although the physical appearance is much the same.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Oct 2007 Posts: 91 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 91 | Thank you for the info, I'm just researching for another possible project, my mistake thinking a 1936 was a 216. | | |
