2 members (Hotrod Lincoln, Shade Baby), 66 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
I am re-powering my '51 Chevy 3/4T from a 235 to a 261. I plan to use a 261 block and a 235 848 head to gain compression. Since the rocker arm assembly from the 261 is in the best condition, I am planning to use it for the build. I notice that the two end rocker shaft supports from the 261 have a slot milled into the side where the shaft goes through, which I suppose is so the shaft is held securely. Is this correct? What is puzzling is that the 235 rocker shaft supports are all solid with no slot. Does anyone know why they are different? Are both supposed to have the slot and maybe the PO installed the wrong end supports? Any help would be appreciated.
Rocker Shaft Support with slot
Joe,
Hope that someone with experience/knowledge checks in on this one. I have never seen one if those posts with a slot as shown in your photo.
Tim
Joe,
Are there any numbers on the supports?
-Tom
1950 Chevy 3100 w/ 1956 235
Tom
Yes, there is a casting number of 3836114, but it is on both the slotted and non-slotted supports.
Joe
