| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51411 10/21/2005 2:34 AM | Joined: Nov 2001 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 111 | How difficult is replacing the front seal on the rear differential of a 47 3/4 ton truck? It is leaking right behind the driveshaft yoke. It has a bell shaped collar just behind the yoke and then there are 5 bolts holding on a steel flange. How tough is this going to be or does this job usually go fairly easy? thanks!!lowgoer
54 Chevy 5 window - 46 Chevy 1/2 ton
