3 members (David Bush, mk72, Bill Hanlon), 130 guests, and 4 robots.
Topics128,053
Posts1,055,777
#51386 10/20/2005 3:13 PM
Junior Member
Junior Member
When I back up while turning the rear wheels start to bind up. It feels alot like a 4WD with the front hubs locked in and trying to turn on dry pavement although it looks like the rear wheel just can't freely turn. I have a 1972 Chevy PU 4WD with a posi rearend and 3.73 gears. Does anyone have any ideas? :confused:
#51387 10/20/2005 3:55 PM
The clutches in the posi are probably locking up, makes the rear end like it's a solid axle.
#51388 10/20/2005 7:17 PM
Junior Member
Junior Member
is it a 1/2 or 3/4 ton?
1969 GMC K/2500 (w.i.p.)
#51389 10/20/2005 8:44 PM
Marine: My 76 corvette did the same thing, was told to make figure 8's backing up cleared the problem right up. Ben
popcorn The Truth is Out There (Do not no why it just worked)
#51390 10/20/2005 9:47 PM
Riding in the Passing Lane
Change the lube in the rear end. Use GL-5 & put in a posi. additive.
1972 Chevy c10 Cheyenne Super
