1 members (Hotrod Lincoln),
74
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 25 Apprentice | | Apprentice Joined: Feb 2009 Posts: 25 | I put the covers back on after putting the rod back in place. And now it wont run for [censored]! Help I maybe the timing was ajusted way out to compansate for the rod being out. As I have not yet got a timing light I dont know. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Mark53,
Did you have to pull the cap or wires or distributor to get the sidecover off? Did you adjust the intake and exhaust on the cylinder that had the pushrod off.
Just getting the cylinder back on line shouldn't have made it run worse provided you adjusted that valve properly. It sounds like you whacked something out of kilter when you pulled the sidecover. Does this sound possible? Were they solid lifters?
Stuart | | | | | Joined: Feb 2009 Posts: 25 Apprentice | | Apprentice Joined: Feb 2009 Posts: 25 | Yes I popped a couple plug wires of but already went down that road. they are solid lifters I was planning on popping the cover back of an checking them all again tomorrow | | | | | Joined: Feb 2004 Posts: 29,817 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,817 | You don't need a timing light. Just roll the engine over by hand (clockwise from the front)until the BB is under the pointer with the engine stopped, loosen the timing clamp, turn the dizzy clockwise until the points close, and turn back CCW until they just barely open. Lock the clamp down. The timing is set close enough to run without any problems. You can tweak it a tiny bit up or down from there for the best power and least detonation. Jerry
It never hurts to double check. The firing order is 153624, clockwise around the cap. #1 cylinder being up front near the fan.
Stuart | | |
