4 members (baldeagle, Jon G, Oswald, 1 invisible), 57 guests, and 3 robots.
Topics128,015
Posts1,055,334
Members48,419
#513363 03/05/2009 5:48 AM
Apprentice
Apprentice
whats the average running temperature of a stock 235 engine? The reason i asked is because i put some "stop leak" in my radiator and it doesnt seem like the engine gets hot enough to open the thermostat, atleast with the radiator cap off i cant see the water circulating. I had it idling for a good 1/2 hour. I know the 'stat is good because i took it out and checked it with heat.
Rust Lover
wesfab #513364 03/05/2009 5:49 AM
Apprentice
Apprentice
180' thermostat
Rust Lover
wesfab #513419 03/05/2009 12:49 PM
wesfab,
I can't help you because I have the same problem with mine. What does your temp gauge read? I have had my radiator out and flushed when I had it repaired for leaks and have had several different 180' thermostats, that all opened in hot water, but still my gauge only reads around 160'.
After long drives my radiator and heater hoses are too hot to touch and it blows warm (not hot) air. I chalk it up to a faulty gauge. Maybe someone will chime in that is better informed.
Blue 50
1950 3100 w/57 235
Patrick’s Saginaw 4 speed and 3:55 rear end
Blue 50 #513464 03/05/2009 3:20 PM
It's possible the block needs flushing too. Rust slag can clog the system or perhaps your water pump needs to be checked.Try running the motor withouut the thermostat in place and see wht the temp runs then. My temp isusually around 160.
Drew
DrewP #513544 03/05/2009 6:48 PM
Do what Drew suggested, with the radiator cap off. When you reach stable operating temperature, measure the temperature of the fluid in the radiator tank (a cooking thermometer would be OK). This would let you know how close your gauge is to actual temperature.
tclederman #514729 03/08/2009 4:54 PM
Are you sure the thermostat is in right side up
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
