1 members (Peggy M),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 25 Apprentice | | Apprentice Joined: Feb 2009 Posts: 25 | I want to put a new carb on my 235. Its in a 53 4400. just want to no if there is a good carb that wont break me as I an in the middle of getting drivable. | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | I can't speak for anything specific to a '53, but I'm loving my Carter YF, after switching from a Rochester B.
Bill | | | | | Joined: Nov 2007 Posts: 128 'Bolter | | 'Bolter Joined: Nov 2007 Posts: 128 | ive always ran the old Rochester B's, still do on my 2 trucks. Whats the advantages with the Carter? maybe im missin' out on sumthn. yer never too old to learn. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 'Round here, Rochesters have a nasty habit of the float bowls cracking. I've also seen them with warped bases.
Bill Burmeister | | | | | Joined: Feb 2009 Posts: 25 Apprentice | | Apprentice Joined: Feb 2009 Posts: 25 | Will the carter take any modification or bolt right on? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No mods, direct bolt on. Just make sure you get the Chevy application, as there is a Ford version that is jetted way too rich.
Bill Burmeister | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | I had leakage issues with the B between the top plate and the bowl. The B has 4 screws holding the top plate to the bowl casting. YF has 7 screws holding the top plate to the bowl casting.
If memory serves me, mine is a model 2100. (Use the search tool- there have been many threads in the past concerning the models to look for. I believe carbking and atomarc, among others, had some good advice/observations.) Like the B, it is a manual choke. No difference between the two...except for the extra 3 screws and no leakage!
Just my experience.
Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
