1 members (Ponchogl), 163 guests, and 3 robots.
Topics128,101
Posts1,056,182
Members48,436
#512832 03/04/2009 3:23 AM
Apprentice
Apprentice
I want to put a new carb on my 235. Its in a 53
4400. just want to no if there is a good carb that wont break me
as I an in the middle of getting drivable.
Mark53 #512859 03/04/2009 4:08 AM
I can't speak for anything specific to a '53, but I'm loving my Carter YF, after switching from a Rochester B.
TxLaTx #512869 03/04/2009 4:26 AM
1 Offline
ive always ran the old Rochester B's, still do on my 2 trucks. Whats the advantages with the Carter? maybe im missin' out on sumthn. yer never too old to learn.
'Round here, Rochesters have a nasty habit of the float bowls cracking. I've also seen them with warped bases.
Bill Burmeister
Apprentice
Apprentice
Will the carter take any modification or bolt right on?
Mark53 #512909 03/04/2009 5:16 AM
No mods, direct bolt on. Just make sure you get the Chevy application, as there is a Ford version that is jetted way too rich.
Bill Burmeister
I had leakage issues with the B between the top plate and the bowl. The B has 4 screws holding the top plate to the bowl casting. YF has 7 screws holding the top plate to the bowl casting.
If memory serves me, mine is a model 2100. (Use the search tool- there have been many threads in the past concerning the models to look for. I believe carbking and atomarc, among others, had some good advice/observations.) Like the B, it is a manual choke. No difference between the two...except for the extra 3 screws and no leakage!
Just my experience.
TxLaTx #513732 03/06/2009 2:38 AM
It would be a 2100S.
Bill Burmeister
