7 members (Lightholder's Dad, Wickedbass, Christian, NJC, Hotrod Lincoln, baldeagle, 1955 1 Series), 55 guests, and 4 robots.
Topics128,017
Posts1,055,338
Members48,419
#512458 03/03/2009 4:12 AM
Hello,
Starting wiring that was previously removed by someone else.
Just wondering when the wiring runs from the tail lights to the cab does the wiring harness run with in the frame or is it attached to the exterior of the frame via clips?
Thanks for the help!
41chevy!! #512746 03/03/2009 11:26 PM
on my 46 the original tail light harness did run on the inside of the drives side frame rail, held on by spring clips
jrm4x4 #512753 03/04/2009 12:02 AM
Mine runs in the frame channel if thats what you are asking.
rick
elmer46 #514731 03/08/2009 5:00 PM
My '41 still had a few of the clips on the inside of the frame channel even though the wiring was gone
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
Kip's41 #516420 03/13/2009 1:33 AM
Thanks guys, started on this today!
