| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 49 | Hello, Starting wiring that was previously removed by someone else. Just wondering when the wiring runs from the tail lights to the cab does the wiring harness run with in the frame or is it attached to the exterior of the frame via clips? Thanks for the help! | | | | | Joined: Feb 2009 Posts: 23 New Guy | | New Guy Joined: Feb 2009 Posts: 23 | on my 46 the original tail light harness did run on the inside of the drives side frame rail, held on by spring clips | | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | Mine runs in the frame channel if thats what you are asking.
rick | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | My '41 still had a few of the clips on the inside of the frame channel even though the wiring was gone | | | | | Joined: Mar 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 49 | Thanks guys, started on this today! | | |
