| | | Forums66 Topics128,284 Posts1,058,523 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51170 10/15/2005 3:42 AM | Joined: Feb 2005 Posts: 33 Junior Member | | Junior Member Joined: Feb 2005 Posts: 33 | Hey everyone, I am building myself a little small block 350ci. the block is a casting 3970010. nothing special 2 bolt main. I aquired some Aluminum heads from an 87' Corvette... those are pretty cool. 58cc chambers, angled plugs.... here's my delema. Those heads require a reverse flow cooling, so the water outlet on the intake manifold now becomes a water inlet. this requires me to use a reverse rotation water pump instead of the standard. all my drive pulleys are set for the old fashion counter clockwise set up. does anyone know of an outfit that produces standard rotation reverse flow small block chevy water pumps? thanks for your time ~Mykk | | |
#51171 10/15/2005 5:41 AM | Joined: Mar 2005 Posts: 98 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 98 | it doesn't use reverse cooling.
50 chevy 3100
