1 members (‘37ChevyPU), 86 guests, and 3 robots.
Topics128,211
Posts1,057,476
Members48,473
Junior Member
Junior Member
Hey everyone, I am building myself a little small block 350ci. the block is a casting 3970010. nothing special 2 bolt main. I aquired some Aluminum heads from an 87' Corvette... those are pretty cool. 58cc chambers, angled plugs.... here's my delema. Those heads require a reverse flow cooling, so the water outlet on the intake manifold now becomes a water inlet. this requires me to use a reverse rotation water pump instead of the standard. all my drive pulleys are set for the old fashion counter clockwise set up. does anyone know of an outfit that produces standard rotation reverse flow small block chevy water pumps? thanks for your time ~Mykk
it doesn't use reverse cooling.
50 chevy 3100
