1 members (baldeagle), 32 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#511182 02/27/2009 8:16 PM
Apprentice
Apprentice
OK I got my front and back windows in. WHAT A #$%#@!
Now I'm down to the lights. Any tips the headlamp terminals are junk. I was gonna just replace them an all the wires. Or should I just rewire more to new specs.
Mark53 #511190 02/27/2009 8:56 PM
Riding in the Passing Lane
I dont understamd the question but the connectors are available new at any parts store.
1972 Chevy c10 Cheyenne Super
Mark53 #511549 02/28/2009 7:27 PM
Apprentice
Apprentice
Should I just replace wires to keep it the same.Or just get one the new conversion wiring kits.
Mark53 #511560 02/28/2009 7:44 PM
What is it you want to convert to? What year is your truck? What voltage is your electrical system? Are you referring to using relay switched lighting?
Cletis #511605 02/28/2009 11:18 PM
Apprentice
Apprentice
Oops sorry its a 53. just wondering if I should just change it wire for wire or buy one of the kits on the classic car sites.
The one I saw did away with stuff like the terminal blocks. It is already a 12v so I don't have to worry about that.
Mark53 #511606 02/28/2009 11:20 PM
Apprentice
Apprentice
Also I am not sure how to get the headlight knob off so I can get to the switch any idea
Mark53 #511634 03/01/2009 1:22 AM
62401
Mark,
Most of these trucks have trashed wiring so if you're going to be messing around with it anyway, why not just go all the way and rewire it? The aftermarket wiring harnesses from Jim Carter or American Classic are pretty good and come with step by step instructions.
On the headlight switch, there a hole in the underside of the switch body -- stick an awl or small pick tool up in there to release the detent that holds the knob post in. Look around the body of the switch (you have to lay on your back under the dash ...) and you'll see what I mean.
Good luck.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
