Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (TUTS 59, Peggy M, Gdads51, 68ironhead, tclederman, 2-Ton, wilbur53), 154 guests, and 7 robots.
Topics128,281
Posts1,058,476
Members48,490
#510877 02/26/2009 11:27 PM
whats the main adjustment screw supposed to be on a 235 with a rochestor. I need a starting point
mightymousem6,
The typical adjustment for the idle mixture screw is approximately 1 1/2 turns out from fully seated.
Stuart
My recent search turned up the opinion by several that the "tried and true" 1 1/2 turns out should actually be "3 turns out" with modern fuel. I don't have enough experience to comment, but food for thought.
My Auto Restorer showed up today. In an article by Milt Webb MiltTheInstructor.com, he is tuning up a 27 Hupmobile. He discusses opening the idle mixture screw until the engine stumbles (over-rich), then closing the screw in until it runs smoothly again, then in further until the RPMs drop off (lean point). Final adjustment is half way between these two points (generally). This assumes everything else is tuned, ie: timing, advance, plug gap, point gap, etc. and should be done on a warmed up engine.
Sounds stupid, I know, but I never really thought of this. headscratch Makes sense.
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
Riding in the Passing Lane
I always start with it screwed out 2-3 turns. Turn it in slowly till it starts to slow down. Then back it out just enough to bring it back to speed. This is similar to Milt's system & was used for many years till they started with emission controls.
1972 Chevy c10 Cheyenne Super
1 1/2 turn off the seat always works good for me.
SlickT
