3 members (lumbersawyer, Shade Baby, TexasA&M48Truck), 88 guests, and 1 robot.
Topics128,094
Posts1,056,487
Members48,444
I plan on putting a water pump adapter on my '54 1-1/2 ton which will be powered by a '62 235 from a '62 c-10. What is the ideal water pump pulley to harmonic balancer pulley ratio so the water pump isn't spinning too fast or slow?
You need a balanncer from 54 or earlier that takes the same width belt as your pump.
For the 3/8" belt an acceptable substitution is to use a 1955-62 truck balancer. This balancer is designed for a 1/2" belt but may be used with a 3/8" belt. This will allow the belt to run deeper in the groove and in affect will reduce the diameter to very near the correct size.
My Blog
