| | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50923 10/07/2005 8:30 PM | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | When installing new gaskets for the oil pan, which goes on top. The cork gasket, or the rubber one around the bearing. I have the motor on an engine stand, and have it turned over so that I am looking at the bottom of the motor. It would seem that the cork gasket would go on the motor first with the rubber bearing gasket then going on top in the corners where they overlap, so that when the oil pan is put on it will press against the rubber gasket first, and then tighten against the cork one, but I'll bet that is wrong. Thanks Allen | | |
#50924 10/07/2005 8:38 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Bakerallen, I'll bet it ISN'T. You were correct Allen. Don't forget a little glob of silicone in those corners where the rubber and cork gaskets meet. Make sure to hammer your pan flange real flat and don't get out the 24" cheater bar when you tighten your pan! :p
Stuart. | | |
#50925 10/13/2005 3:00 PM | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | Stuart: Thanks for the help. I have the pan in place. We will see what happens when the motor goes in and starts for the first time. Allen | | |
