1 members (MikeE),
121
Mod | | | Forums66 Topics128,129 Posts1,056,360 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50779 10/01/2005 5:59 PM | Joined: Aug 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 47 | My truck has the three speed column shift On my past two outtings I have noticed a "clanking" noice while accelorating in 2nd gear. But worse, twice while smoothly driving in 3rd my gear shift lever popped up into neutral all by itself leaving me coasting.
Had to slow to almost a stop to get it back into gear.
Will be bringing it into my local mechanic next week ...but would like some input as to cause, and whether this means an adjustment or a new tranny.
Thanks. Bart | | |
#50780 10/01/2005 7:58 PM | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Popping out of gear is common on sloppy worn trannys.. my '50 1/2 ton would do that occasionally, but only in second.
My '50 1/2 ton would clang.. but only in second gear. It turned out to be the u-joint inside the "torque tube" deal right behind the transmission.
It didn't clang in faster gears because the RPM's of the joint were fast enough at higher gears that centrifigual force kept it from clanging.
Kind of like an out of balance tire.. the "shimmy" will be more noticable at a certian speed.. the higher or lower you get from that "ultra wobble" speed the less noticable the problem.
Sounds like you could benefit from a tranny rebuild and a new joint from the torque tube to the transmission.
#50781 10/02/2005 2:45 AM | Joined: Aug 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 47 | Fumblin,
This is great info. I'll show this to my mechanic. Thanks so much for taking the time. Bart | | |
#50782 10/02/2005 2:47 AM | Joined: Aug 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 47 | Fumblin, this is great info. thanks so much for takin the time. I'll show this to my mechanic. regards, Bart | | |
#50783 10/03/2005 7:35 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Take a look at the shift box on the column. There are rubber bushings on the arms on the box that hold the rods. New bushings might reduce the play and help it stay in gear. Also you might be able to adjust the rod at the tranny end. Worn out motor mounts can also cause it to jump out. Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
