| | | Forums66 Topics128,147 Posts1,056,801 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | I'm doing a rattle can restoration of an old 1940s garden tractor chassis. It has a lot of cast iron parts that are greasy and oily. How can I clean them so that primer and paint will stick?
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | Pressure washing them should work good. Samantha | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | you can scrape off what you can. you could use some degreaser too. powerwash it after that. it may not all come off anyway. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Kerosene. It's great. Like Tony the Tiger great. After that, steam is nice if you've got it. A putty knife and a wire brush is also helpful.
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Soaking it with something like Simple green and then pressure washing will get a lot of it. You will probably never get all the dirt, but painted dirt doesn't always look that bad. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Cleaning cast iron parts is one of the few things rotary wire brushes excel at. Get all the oil and grease off with solvents or pressure cleaning and then put the wire brushes to it. You'll be amazed at how much hard, dry crud remains especially in the all the nooks and crannies. It's almost indistinguishable from the iron. EXAMPLE | | | | | Joined: Feb 2009 Posts: 8 New Guy | | New Guy Joined: Feb 2009 Posts: 8 | The '40 216 engine that I am working on was covered with 68 years of oil and red clay, some of it hard as a rock. We sprayed it with simple green twice, pressure washed it 3 times and it still had a quarter inch of crud on it. Then I got 2 cans of oven cleaner at the dollar store. Sprayed it on and let it sit for a day. Pressured washed it and got to bare metal. Then you can see all of the hard stuff in the corners to scrape with a dull knife. Good luck.
| | | | | Joined: Feb 2009 Posts: 8 New Guy | | New Guy Joined: Feb 2009 Posts: 8 | We use oven cleaner and hot water powerwashers on antique tractors then primer with a buff colored primer and paint
Clint Youse Paris,MO
| | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | Scrape or wire brush what I can. Oven Cleaner and pressure wash large intricate stuff (motors frames, etc. and kerosene on small stuff (fits in rubbermaid tub). Pressure wash to remove oven cleaner. Phosphoric acid (Phospho - Home Depo) brush for large stuff, dip-n-soak small stuff (again rubbermaid tub). Large stuff looking at Eastwoods Rust Encapulator http://www.eastwoodco.com/jump.jsp?itemID=24048&itemType=PRODUCTWire brush small stuff. Primer and paint. Looking for a way to preserve the beutiful finish of the cast. Clear laquer does not seem ot hold up, but without primer can't say I blame it. Anybody know of a clear primer or good cast iron silver/gray paint lookalike? Brett | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If the parts are removable and small enough to fit in a bucket or small barrel, a long soak in a solution of lye works really well (take the appropriate steps to protect yourself from a caustic solution). You can leave the parts in there for as long as it takes, they won't rust or ablate. Lye only attacks the grease and oils. Its the same active ingredient as oven cleaner. A can of Red Devil powdered lye will do you right up.
I would just throw the parts in lye for two or three weeks, leave them in the sun, and stir them once in a while. A good rinse and paint is all you need after that. Engine manifold paint resembles virgin cast iron pretty well, but does not cure very well without heat.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I use the foaming engine cleaner, then pressure wash. Then repeat. Then use POR15.
