5 members (Oswald, 55shaker, Barney1951, Otto Skorzeny, WICruiser), 83 guests, and 0 robots.
Topics128,050
Posts1,055,646
#506690 02/17/2009 1:28 AM
While tearing apart our front axel, there were some castle nuts with cotter keys. I got a few of the cotter keys out but the others I had to just break off and run the nut over top. What's the best way to remove the broken-off pieces in the threads??
Use a small pin punch, or carefully center punch the end of the cotter pin and drill it out. Most of the front end pins are either 3/32" or 1/8". Be careful not to break off the drill bit in the hole.
What Jerry said. You will find the cotter pins are soft and the bolts much harder so drill with a small bit first then try a punch.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
I use a HSS drill bit slightly smaller than the hole and CAREFULLY tap it thru with a brass hammer. Take your time and don't whack it hard. Hope this helps.
I always try to blow through the hole with an air nozzle before resorting to the drill bit. A lot of times it spits the leftovers right out of the hole.
Paint & Body Shop moderator
