0 members (),
89
0
Mod | | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | While tearing apart our front axel, there were some castle nuts with cotter keys. I got a few of the cotter keys out but the others I had to just break off and run the nut over top. What's the best way to remove the broken-off pieces in the threads?? Thanks | | | | | Joined: Feb 2004 Posts: 29,765 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,765 | Use a small pin punch, or carefully center punch the end of the cotter pin and drill it out. Most of the front end pins are either 3/32" or 1/8". Be careful not to break off the drill bit in the hole. Jerry
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | What Jerry said. You will find the cotter pins are soft and the bolts much harder so drill with a small bit first then try a punch. | | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | I use a HSS drill bit slightly smaller than the hole and CAREFULLY tap it thru with a brass hammer. Take your time and don't whack it hard. Hope this helps.
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I always try to blow through the hole with an air nozzle before resorting to the drill bit. A lot of times it spits the leftovers right out of the hole.
