5 members (32Fordpuchoptop, 55shaker, TUTS 59, panel fan, UtahYork), 74 guests, and 0 robots.
Topics128,078
Posts1,055,940
Members48,430
#505949 02/14/2009 9:39 PM
I asked this question over in the Electrical Forum and never got a clear answer so I'm trying here.
Is there any way you can tell the difference between a 6v and 12v heater motor? The one I have wasn't hooked up but it does have plastic/rubber coated wires, not cloth. When I hold the wires to a 12v battery for a few seconds it runs and doesn't start smoking or anything.
I'm electronically illiterate and needing some help on this before I commit to installing my heater.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #505956 02/14/2009 10:12 PM
Woody,
IIRC, I asked this same question to my friend that owns a motor repair shop. Again, IIRC, the resistance value of the windings, measured with an ohmmeter would be about the only way to tell, and I have no clue what they would be.
Having said that, my thought would be to 'listen' to the speed of the motor. I think a 6 volt motor connected to 12 volts will sound 'too fast' even to the untrained ear. If you hook your motor up to 12 volts and it sounds reasonable, I'll bet it's a 12 volt motor.
Your observation about wire insulation could be right on the money. A true vintage motor would probably have the brown cloth covering whereas a more modern 12 volt motor might have true plastic insulation, but this again is just a guess.
Stuart
atomarc #506088 02/15/2009 4:24 AM
HI, yes a 6 volt motor that is hooked up to 12 volts would run at 2x its normal speed , the only way to really find out if its 6 volt or 12 volt is to take a ohm reading the only problem is You have to have one that You know is 6 or 12 if You want I just took out My 6 volt heater motor today I can OHM test it tommorow and give You the reading , Pete PS. You got a OHM meter ?
Pete52 #506139 02/15/2009 1:00 PM
Hi Pete,
Man, I would be very appreciative if you could do that for me. Yes, I have access to an OHM meter... a friend will test mine. It's embarrassing but I don't know an OHM from a volt.
Woody
Door Art Collection
Czechman #506192 02/15/2009 4:18 PM
Woody, I had the same problem on my 55 1st series, If the motor runs at really high speed it is a 6 volt, I cured my problem by ordering a part # EL135 H.D.voltage reducer from Jim Carter. Problem solved.
steve
" Hard Times Don't Last , Strong People Do."
steve Hales #506195 02/15/2009 4:25 PM
Steve, That's good to know but first I have to find out if mine is 6v or 12v.
Woody
Door Art Collection
Czechman #506267 02/15/2009 9:46 PM
Hi,its 37.3 OHMs that is on a 6 volt that I took out of the truck on sat. Pete
Pete52 #507161 02/18/2009 3:16 AM
Thanks Pete for the info and the PM.
Woody
Door Art Collection
Moderated by  ndkid275, Phak1
