4 members (Shardean, Tstan7, 2 invisible), 94 guests, and 4 robots.
Topics128,022
Posts1,055,353
Members48,420
#504 12/24/2001 7:15 AM
hello all, i just replaced the carb on my 250 (the old one was stripped out at the fuel intake opening). I got the "new" carb from a local yard and it seems to be the same type rochester monojet. I don't know anything about these things and my problem is the engine starts up (have to pour a little fuel down the carb) and runs fine, however when i push the accelerator the carb "gasps" and the engine stalls. What's going on here? thanks for any replies.
1948 GMC 250 Series Flatbed
#505 12/24/2001 10:56 AM
onetongmc: You should not have to add fuel to start. Possible troubles can be many.
Do you have fuel delivery to the floatbowl? Are gas lines and/or fuel filter blocked? The idle mixture may not be set correctly, and possible vacuum leak, and/or plugged idle port, or the engine would/should start. Accelerator pump may be worn/leaking and not performing to specs. Float needle/seat may be worn or float level not set correctly. The list goes on!
When you buy a used carb you don't know what kind of shape its in, or how long its been sitting, your setting yourself up for trouble ahead!! Sometimes there plugged up and/or gummy and dirty. Usually full of trash. Even if you have picked up a brand new carb, you still have to check things out and adjust as needed. Just because something may be new, does not guarantee its right and/or adjusted correctly.
You are at a point where you have to make a decision about your next move. You have 2 choices. 1. You have to pay a shop to fix your carb. 2. Or educate yourself about your carb/truck and fix it yourself.
If I were you, I would go with number 2 because its cheaper and more fun. Carb repair is not hard, deep, or involved. Arm yourself with some knowledge. Buy a shop manual for your truck, or book on your engine/carb. In it, will be a section on your carb, and will take you through a step-by-step explaination of all the carbs systems, and overhaul, and any and all necessary adjustments.
You can buy a carb rebuild kit from the nearest NAPA or autoparts store. Most carb kits include instructions, complete enough to guide you through what you need to do and adjust. No rocket science here, just basic "Stovebolt Science 101". Piece of cake!!!
Hope this helps!!!
smile wink
Houston? , We have a problem!
#506 01/02/2002 7:54 PM
One-ton GMC,
I'm with Chevyman; your present starting/gasping problem is most likely from a non-working accelerator pump- my experience has been that the leather plunger dries out if the carb has sat idle for more than a month or so.
Get a kit and rebuild it.
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
#507 01/04/2002 5:25 AM
Frank and Chevyman are right. I had the same symptom on my 1965 305E's Bendix Stromberg WW...it would "carb fart" upon accelerating or 'punching' the throttle. This usually indicates a lean conditon caused by the accelerator pump not providing the extra squirt of gas as the butterfly opens rapidly. NAPA should have a rebuild kit for you....mine was $17. Good luck and have fun with it. You'll get a lot of satisfaction out of doing it yourself and it requires no special tools.
Scott grin
Scott
1964 GMC 1002 Long Wideside w/305E V6 & sm420 "Blue Jeans"
1996 Harley Davidson FLHTCI
1981 Husky 250CR
http://community.webshots.com/user/gmc1002hf5669a
