1 members (TIM ZINDLER),
104
Mod | | | Forums66 Topics128,269 Posts1,058,403 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | I've had a lot of off & on trouble getting my 52 GMC to not hesitate and to just generally run well. FINALLY FIGURED THE PROBLEM!!! For some reason I never loostened the vacuum advance from the distributer. When I did that I was able to get the timing advanced far enough to make the little 228 RUN. The timing light is useless though because the marks aren't anywhere they are supposed to be. BUT WHO CARES. My wife can drive it now cause there's no hesitation and lots of low and top end power. I know I'm probably not the only temporary bonehead out there so I thought you would appreciate the story. Jim | | | | | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | Timing marks being off could mean the carb mixture and idle are poorly adjusted. I had a Willys CJ2A engine that I couldn't get to run with timing set properly, but my mechanic cousin adjusted the carb and the timing came into line. He had a dwell meter and an idle meter which also helped diagnose the problem.
I thought the same as you at first. I had idle set way too high, but can't remember if mixture was way too lean or rich... Purred like a kitten after the tuneup.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The point gap also affects the timing, but it shouldn't change where the timing mark falls. For a good diagnostic tool, get a vacuum gauge, about $15 at a parts store. For info on use: http://centuryperformance.com/vacuum.asp
Fred 52 3600 69 C-10
| | | | | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | I'm using the Petronix pointless ignition so I don't have a dwell time. I probably will do the tune up deal when I get some time but for now I'll leave well enough alone. I realize the marks have to be there somewhere close. jim | | |
#5060 05/19/2004 11:10 PM | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | Thanks for the link Fred. Good info.
35 + years of rollin' steel!
