4 members (NJC, Steveoreno, TexasA&M48Truck, Otto Skorzeny), 80 guests, and 3 robots.
Topics128,193
Posts1,057,238
Members48,465
I was wondering what a holley/weber progressive 2-bbl carb does to the low end torque vs. a stock rochester 1-bbl. The engine I have is a 1962 235 out of a 1962 1/2 ton that has been rebuilt to stock specs. The truck is a 1954 4100 1-1/2 ton with a sm 420 with a 2-speed rear. I posted a thread a few weeks earlier about running split stock exhaust manifolds on the same application. I wanted to know if these would be wise to run in this application. I live at 4300 feet about sea level and will occasionally climb a 6% grade to elevations of 8600-9000 feet above sea level. I plan to have this truck loaded with my construction tools and may pull a trailer with equipment(i.e. skid steer loader, pickup truck, or tool trailer). I will eventually build a 261 to fit my needs in the future. I am running 8.25-20 tires as well.
ODSS President
ODSS President
Not to be a wiseguy but how many bolters on this board drive in these conditions....."I live at 4300 feet about sea level and will occasionally climb a 6% grade to elevations of 8600-9000 feet above sea level." Your headers are the wisest bang for the buck as the exhaust gases are expelled more freely, read: less restriction yielding more horsepower.
I've been running a H-W for 7 years now on a half ton daily driver with overdrive and Fenton headers. Works like a charm, fuel mileage as high as 21 mpg highway. I hope carb people or big truck people chime in to give you perspective, if they don't go ahead and email them direct. We all want you to succeed. Regards, Cosmo.
~ Cosmo
1949 Chevy Half Ton
