0 members (), 148 guests, and 0 robots.
Topics128,101
Posts1,056,182
Members48,436
2 Offline
Did the T5 swap and wanted the short throw shifter because I used a old four speed shift lever. I did not want to spend a lot of time building a one inch spacer plate. I cut four one inch pices of 1/4 inch pipe and bolted them to the shifter mounting holes. I then cut four lengths of 5/16 x 1 inch steel strap that fit between the pipe. I welded the strap to the pipe. The shift pen has to be moved up one inch like the tech tips says. I took the pipe and strap off cleaned and painted it put it back on with some silcone sealer. There is no oil up there so all you need to do is keep the dirt and water out. You might have to drill the pipe out to fit the bolts. This went to geather very fast and all you need is a welder and a way to cut your steel.
Pictures if ya can! smile
1946 Chevrolet 1/2-ton
More pix on Photobucket
see john's tech article wave john live's in my old home town
http://www.stovebolt.com/techtips/shifter/index.html
here is my version using a block of dense machinable plastic, UHMW, that cost me a $1.00 grin wink
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=584226-R1-004-0A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=584226-R1-006-1A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=584226-R1-008-2A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=584226-R1-010-3A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=584226-R1-012-4A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=584226-R1-014-5A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=584226-R1-014-5A-1.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=584226-R1-016-6A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=584226-R1-040-18A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=584226-R1-042-19A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=584226-R1-044-20A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=584226-R1-046-21A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=584226-R1-048-22A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=584226-R1-050-23A.jpg
my T5 short shifter has a welded 1/2'' rod x 2'', threaded to accept a coupler and
lock nut, shift rod is about 15+'' and tapered about 8'' at the top. a threaded stud 5/16x24 to accept an old fashioned black knob. dance
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=2A-2.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=584226-R1-028-12A.jpg
Jim & Caroline
Big'n,
I have full set of picts on the Fliker site below.
Mine is aluminum like Jon's, but experimented and went with thicker piece and tightened it up a bit more. Works fine.
Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
