0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | just to make sure: I can simply pull it off with a puller, right? no hidden lock nuts, pins, etc? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Assuming it's the same balancer set up as on my 38, yes. Just make sure you're pushing against the end of the crank and not the hand crank lugs. Also pull using the threaded holes in the balancer, not the outside edge. If the 27 is different from my 38 disregard all of the above.
| | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | the guys on chevytalk said just pull, but careful. thanks tiny! | | |
