1 members (1 invisible), 83 guests, and 3 robots.
Topics128,032
Posts1,055,519
Members48,425
#50529 09/26/2005 5:25 PM
Junior Member
Junior Member
Has anyone tried air bags, coil over shocks, removing leaves, or fiberglass leaf springs to improve the harsh ride of the stock front leaf spring suspension on a 51 Chevy? I know people spend a lot of money and time to weld in anew front suspension with A frames and coil springs. Just was wondering if there was not a simpler, cheaper way to get a better ride. Thanks.
Cbaymac
#50530 09/26/2005 5:48 PM
I've got lowered springs, drop spindles, a sway bar, steering dampner and gabriel load leveler coil overs on the front of mine and it doesn't ride too badly, not was well as an indpendant front suspension would, but not as bad as it did.
#50531 09/26/2005 8:37 PM
DJ Offline
Drop spindles? Who sells those? I know of dropped axles but spindles?
#50532 09/26/2005 9:44 PM
I've been curious about the sway bar. Did you notice an improvement in handling? My '51 has good kingpins and shocks and the steering is properly adjusted, but I get that "danger, Will Robinson, danger" feeling when I go into a corner.
#50533 09/27/2005 4:41 AM
I bought GMC van seats for my truck and that helped out considerably on my rather stiff 1 ton. But don't know if you want to change the interior like that.
#50534 09/27/2005 5:22 AM
Patrick's, out of Casa Grange, AZ has a lowering kit that drops an AD @ 2" and provides a smoother ride. It doesn't require a sway bar and includes new shackles, shocks for @ a grand.
www.patricksantiquetrucks.com
#50535 09/27/2005 10:03 PM
I think the rear sway bar from CCP helped. In retrospect I could have pulled a stock rear sway bar from a Caprice or other similarly sized car and bought the bushings/mount kit aftermarket from lots of places, including AutoZone
#50536 09/30/2005 1:33 AM
Junior Member
Junior Member
NM51. I agree, too many other ways to do things cheaper. I need an old Monte Carlo or S-10 long bed.
http://mcpheter.com/puvet.jpg
Cbaymac
