Did the T5 swap and wanted the short throw shifter because I used a old four speed shift lever. I did not want to spend a lot of time building a one inch spacer plate. I cut four one inch pices of 1/4 inch pipe and bolted them to the shifter mounting holes. I then cut four lengths of 5/16 x 1 inch steel strap that fit between the pipe. I welded the strap to the pipe. The shift pen has to be moved up one inch like the tech tips says. I took the pipe and strap off cleaned and painted it put it back on with some silcone sealer. There is no oil up there so all you need to do is keep the dirt and water out. You might have to drill the pipe out to fit the bolts. This went to geather very fast and all you need is a welder and a way to cut your steel.
my T5 short shifter has a welded 1/2'' rod x 2'', threaded to accept a coupler and lock nut, shift rod is about 15+'' and tapered about 8'' at the top. a threaded stud 5/16x24 to accept an old fashioned black knob.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
Big'n, I have full set of picts on the Fliker site below. Mine is aluminum like Jon's, but experimented and went with thicker piece and tightened it up a bit more. Works fine. Cavebull
